Gar6more2D
        This code computes the analytical solution of waves propagation problems in 2D homogeneous or bilayered media, based on the Cagniard-de Hoop method. In the homogeneous case, the medium can be acoustic, elastic or poroelastic; infinite or semi-infinite with a free boundary or a wall boundary condition at its end. In the bilayered case, the following coupling are implemented (the source is assumed to be in the first medium) :
  • acoustic/acoustic
  • acoustic/elastic
  • acoustic/poroelastic
  • elastic/elastic
  • poroelastic/poroelastic
Please let us know if you need other types of coupling, we will try to implement them as soon as possible.
Gar6more2D is provided under the CeCCIL-B Free Software License.
Gar6more2d homepage: http://gforge.inria.fr/projects/gar6more2d/.
